High pitched noise after opening drivers door (no lights on)
Postby jamsandwiched » Wed Sep 08, 2021 9:37 pm
Hey folks,
I've managed to kill my 2017 transit custom starter battery a couple of times now, I think by opening and closing the drivers door - every time I open the drivers door there is a soft, but audible, high pitched noise coming from the engine bay. Any ideas as to what it can be?
I spent the day cleaning my van after being away in it for a week, all rear doors were open for the day so I don't think it was the welcome home lights going on and off all day. All my interior lights have been disconnected so it's definitely not those. I purposely tried to not open the drivers door much but I had to a few times, each time triggering this noise from the engine bay, it persists for a couple of minutes when the lights are off and the van is locked.
I didn't think much of it until today when I went to start the van again and it was totally dead - it's now being charged via a smart charger. It's the second time it's happened now in a very similar situation after working on the van for the day.
Edit: To add, when we're away in the van, once we're parked up for the night, we try our very best not to use the drivers door due to this noise fearing that's what's causing the battery to die. We've opened the side doors/back doors plenty but they don't trigger the noise, and they've never killed the battery when we've been camping etc. It only happens when the drivers door has been opened and closed multiple times.
Any help would be hugely appreciated as it's very frustrating!
Cheers,
Jam
jamsandwiched
Re: High pitched noise after opening drivers door (no lights
Postby coonak » Thu Sep 09, 2021 5:57 pm
I've get that same noise on mine, its been there since new, no problems with the battery though which is almost three years old.
98 Hiace
2000 Hiace
2003 125 280 gone injectors!
2010 85 280 gone ULEZ!
....68 105 280 Custom eco blue
2018 130 350 Mk8 L3 H3
coonak
Postby Eveshamhardcore » Fri Sep 10, 2021 4:54 pm
Mine has always done that.
No problem but I have killed the battery once without explaination (locked on drive) and twice when camping (in and out of the front & back)
Eveshamhardcore
Postby jamsandwiched » Sat Sep 11, 2021 10:55 am
Cheers for the responses folks! I've been camping a lot of the last year but i've never had it die on me regardless of how many times i've been in and out of the back/side doors/passenger. It's only ever happened at home when it's been on the drive and the drivers door has opened numerous times throughout the day. One thing I do want to check is when the dash panel/instrument/radio turns on too, whether it's just when you unlock it or whether opening the drivers door triggers that too.
Even understanding what that noise is would go a long way to figure out if it is what I suspect it is that's killing my battery.
Ideally I need to get my solar panel to charge the starter battery once the leisure battery is topped up.
jamsandwiched
Postby Altransit » Sat Sep 11, 2021 12:19 pm
jamsandwiched wrote:Ideally I need to get my solar panel to charge the starter battery once the leisure battery is topped up.
None of the above should affect the starter battery, as it's used only for starting. If the starter battery is randomly going flat, there may be a leak through the alternator diodes that's draining it, or indeed a duff battery :idea:
Postby Woodywoodýwood » Tue Sep 21, 2021 3:36 pm
It might be your egr valve. Mine does it and finishes with what sounds like it opening and closing (squeeky metallic sound)
Woodywoodýwood
Postby Czed » Mon May 06, 2024 4:04 pm
Hi Jam
I know You posted this issue a couple of years ago. Did you ever get the resolve?
Strangely I am experiencing your exact issue, word for word
Be great if you can point me in the right direction to solving mine
Carl
Czed
Postby ake » Sun May 26, 2024 3:03 pm
The noise is the pcm waking up, which if done often enough between starts will flatten the battery
The programming can be changed using forscan so the the pcm doesn’t wake up when the door is opened
Postby Friday » Tue Oct 21, 2025 2:44 pm
Hello ake
I have forscan what option do i pick to disable PCM
Friday
Postby whatfriends » Tue Nov 11, 2025 11:28 pm
ake wrote:The noise is the pcm waking up, which if done often enough between starts will flatten the battery
I'd be keen to know this too.
Feels like there are so many annoying little things that can probably all be changed via forscan, I just want to save them up and have them all tweaked on one visit...
whatfriends
Postby metalworker0 » Wed Nov 12, 2025 11:02 pm
if it has stop / start .. there is an electric pump that pumps coolant around the heater core when you are stopped, a few weeks ago
my answer from a few weeks ago on similar or same problem
Stop / Start -
One thing that comes with stop/start system on the later ecoblues (mk8 and custom) is an electric pump that pumps coolant to the cabin heater when the engine is stopped. . if it were to malfunction, relay stuck etc, then the pump would carry on running.
Fault code P2600
2. Front Wheel Drive / FWD, ONLY. Your radiator cooling fan is supposed to be running, to cool the engine after its stopped ... which it will do for a couple of minutes after prolonged long journey or in hot summer weather. or slow traffic ... but its trying to do that... but its seized.
3. FWD ONLY - Same as above but fault with radiator fan control unit, which is mounted on or near the fan motor ... Test 2 and 3 - by un-plugging it.
4 . Something wrong with the cooling system .. getting too hot / overheated .. and you are hearing "heat soak" causing, sort of a "water hammer"
5. A stepper motor controlled device such as EGR or turbo actuator .. has a relay at fault.
Return to Transit Custom
