Rear cargo lights
Rear cargo lights
Postby bigholty » Wed Nov 17, 2021 6:40 pm
2016 2.2 custom.
Cargo lights only stay on for about 10 seconds ... Anyway to alter the duration?
2016 custom 2.2 swb ( current)
mk7 100 t330s 2.4 RWD.
Mk5 smily 2.4 RWD
MK3 2.0 pinto transit.
T3 2.0 air-cooled VW transporter.
Cf Bedford 2.3 litre petrol .
1972 ford F150 5.0 LWB straight 6 petrol pick up
Mini van ...1100cc .... First vehicle.
bigholty
Re: Rear cargo lights
Postby Altransit » Thu Nov 18, 2021 10:16 am
It could be that your battery is past its best, and the BCM is detecting a voltage drop.
Try opening a cargo door, with the engine running, and see what happens :idea:
Postby dunf » Thu Nov 18, 2021 2:03 pm
bigholty wrote:2016 2.2 custom.
Do you mean after the doors are all CLOSED? If so, you can turn the cargo lights to stay on using the controls on the cab headliner light.
If you mean after the doors are OPENED, then yeh, that's unusually short. Normally stay on for about 20 mins.
dunf
Postby bigholty » Fri Dec 03, 2021 10:44 pm
With rear side open or back doors open.. Lights only stay on 10 maybe 15 seconds , open the front door then the cargo lights stay on for ages.. Which is what I'm having to do, which in the rain is no good...
Mk5 smily 2.4 RWD
bigholty
Postby bigholty » Wed May 18, 2022 7:07 pm
Sussed it ...
Side load door switch didn't work..
Fitted a new one so all is good... But now the bloody lights stays on for ages...so I pushed the door switch in...drilled a 1mm hole through the switch body and the depressed pin ..drop an R clip through hole, hepresto lights go out after 10 seconds ,remove r clip and they work as normal..
One word of warning , you don't get the warning the side door is open if ther clip is holding the switch closed....drove off spreading a box of fittings across building site I was on....
Mk5 smily 2.4 RWD
bigholty
Postby richbee » Fri May 20, 2022 2:04 pm
bigholty wrote:Sussed it ...
oops :lol:
I fitted a switch in the plastic surround of the rear cargo lights, so you can choose if they come on at all (they still work off the door opening, so you can't switch them on with the door closed), saved me further flat batteries when I was working on converting the van
richbee
Return to Transit Custom
