Hi guys, I am installing a CTEK D250SE in a 2017 Tourneo eu6 so I need an ignition signal. I have found the ignition switch fuse 5A but is this correct or does this drop signal when the engine is running?
Which fuse would you recommend tapping if not the above ignition switch fuse?
