Hi all
I have a problem with the headlights on my 2013 Custom. When on the automatic setting, at night, the front headlights only function as dipped headlights. This gives me just enough light to drive by (on unlit roads) but is undoubtedly dangerous. All other lights works fine, including the full beam and the side lights that come on when you turn. On manual setting it is the same but when I turn the headlights to 'off' the headlights come on, with everything else, i.e. back lights, off as you'd expect. I get a 'dipped beam bulb fault' error when I start up but this has been the case since I got the van (2-3 years ago) and I've basically ignored it since then. I'm not sure when the fault started but it's definitely a fairly recent development that has only become apparent since the nights drew in.
Any advice would be gratefully received. I wondered whether the sensor may be going or whether a problem with one of the bulbs is leading to an electrical imbalance, or sumfin. To reiterate, the main bulbs themselves are fine yet only come on 'properly' when I turn the lights off!
Thanks in advance
Dave
