Hi all, after some help I’m pretty handy with the tools but only have a trolley jack and axle stands.
My van had a new turbo last year, lately I’ve noticed a hissing/whooshing sound while accelerating above 2.5k. It seems to be getting worse. I have checked over all boost hoses and can’t see any splits or leaks.
While I was under the van I noticed a lot of oil on the gearbox, looked up and it appears to be coming from the bottom of the turbo, what I’m assuming is an oil feed/return pipe. It’s directly on the bottom and has 2 what looks like M6 bolts holding the pipe on, I can see oil around and on these 2 bolts and certain this is where it’s coming from.
Would this be the cause of the noise while accelerating? Any tips and pointers on how to get the turbo off, is this a job that can be done from above and below with axle stands? Is there some kind of gasket or seal on this pipe that would be causing it to leak?
Also a bit of oil in the intercooler pipe, is this normal?
Cheers
