My 2015 Custom 2:2 has had a couple of issues today.
First, it showed the “I” info light and advised that service is required.
I reset this with the brake and throttle pedal trick, it was fine for 150 miles and then came back on.
I repeated this and 15 minutes later it did it again.
Then the engine management light came on and stayed on.
I found the ignition switch on and off three times cheat to get the EML light to go off and all seems well (for the time being)
Although the fault appears to have cleared, I get the message Oil Change on turning the ignition on.
Any thoughts on what might be causing it to do this? It had the oil changed about 4 k miles ago.
