richbee wrote:Hi Andy,
It is certainly doable - I have done the same to my identical 2017 LWB double cab. I removed the bulkhead and bench seat, plus the raised floor which comes with the bench seat.
I've had the Tourneo seats fitted - 3 separate, removable, folding seats, which gives the ultimate in flexibility, but required quite a bit of fitting - each seat needs 8 holes drilling in the floor, and the fuel tank needs to be dropped to drill some of them - hence why I got a company to do it for me. You can sell the bench seat to get some money back, but Tourneo seats are much more expensive than they used to be - I've seen them for £800 a set these days.
You will also have some spot welded brackets on the sides where the bulkhead was attached, which can be removed with a spot weld drill - depends how much you want to change things.
We used to fit an airbed in the back behind the bulkhead - but it is much easier now with all the extra space.
dj57ump wrote:richbee wrote:Hi Andy,
Could I ask who you got to do the conversion?
dj57ump wrote:I found a company that does this. Will take my DCIV and put the Tourneo seats in.
Thoughts?
Andy.moods wrote:So I have just seen the tourneo is removeable like the galaxy seats. Is that the type you have Rich?
