2020 Tourneo Rear Seat Stuck
Postby kev-matthews » Sat Dec 31, 2022 3:44 pm
Hi There!
I have a 21 plate Tourneo Custom which I love to bits, I was moving the seats to create some room and when lifting the last handle there was a twang and now one of the floor bolts won't unlock to release the seat. I think I can repair it, but the current struggle is removing the plastic cover around the base of the seat so I can gain access to investigate. I thought it might be just a case of the plastic clips coming off, but they feel a bit stubborn! Does anyone have any experience with this, or is it that I need to use more brute force and ignorance?!
kev-matthews
Re: 2020 Tourneo Rear Seat Stuck
Postby richbee » Tue Jan 03, 2023 11:17 am
Welcome to the forum - Sorry, not sure - I've never had that happen to mine - I did have one of the little red pop out things snap off, but it didn't affect the operation - hope you got it sorted
richbee
Postby TallPaul » Tue Jan 03, 2023 4:39 pm
If the round clips holding those trims are plastic then you need to push the centre out with something small like a drill bit. They’ll be an expanding clip, the centre pin splays it out.
If they’re metal (ally) then they’ll be pop rivets and you’ll need to drill them out.
TallPaul
Postby Abbietorneo14 » Wed Dec 13, 2023 10:01 am
Did this issue get solved and how? Mine gas done this yesterday and no idea how to make it release and can't clip the seat back in properly. Any help would be great
Abbietorneo14
Postby Jaychandler » Tue Jan 30, 2024 2:35 pm
Has anyone fixed this problem I really need to remove my single middle row seat and it’s stuck in!
Jaychandler
Postby Tourneo2019 » Mon Mar 04, 2024 12:39 pm
Having exactly the same problem here - want to get into the workings of the seat to see where the problem is but cant get the plastic covers off
Tourneo2019
Postby washa84 » Sun May 19, 2024 5:53 pm
Hello, i just bought Tourneo Custom 2013 and there is the same issue with one of the rear seat. I can't remove it, one side is stuck, unfortunately near the close the side of a car and even i remove a plastic cover, i can't reach to the mechanism.
washa84
Postby Cbs88 » Sat Nov 30, 2024 7:16 pm
I managed to figure this out. I had a bent catch that was holding the wire catch for one side which meant that it wasn’t holding the cable in place and getting enough “pull” and was almost slipping out of the bracket. Managed to get the wire back in and then used a screwdriver and a mallet to gently tap the catch back into position and it fixed the issue. If only one side is pulling and popping the red tab out, I’d definitely start here. Images isn’t great but hopefully helps.
Cbs88
Postby Eyeball97 » Thu Mar 27, 2025 6:31 am
What a shock. Have this exact problem and find I'm not the only one.
Does anyone have a detailed solution I really need to get mine turned around to conference setting did the middle one first, then removed the drivers side one, so far so good, try to remove the last seat and only one pin pops out.
Eyeball97
Postby boraciner » Sat Apr 26, 2025 6:06 pm
I just had the same issue and fixed it
First check that if the steel rope is pulling the main spring and locking mechanism like in bicycles
On top of the seat there is a fork, if its not pulling
It can be bended. Just bend it to fix to other direction by a plier
If it’s pulling but not Releasing the lock then Remove the cover and try to pull the spring by plier
After you remove the seat now, you are able to remove the locking mechanism
After you remove the mechanism, if you try to open it, you will never assemble it back
But you will still be able to use main functionality of the mechanism by connecting back the main spring
In that case, read indicators will not work, but the seats will still be operational
boraciner
Postby phil495 » Thu Apr 23, 2026 7:41 am
Hi, the same thing has happened to me but ive taken the mechanism apart does anyone have any photos of where the 2 round springs ho and the little one goes please thank you
phil495
Postby Simon86 » Tue May 05, 2026 7:01 am
Has anyone found a resolution? I have a doubt seat stuck on one side and cannot get it out?
Simon86
Return to Transit Custom
