Robbieben wrote:If you reset the learned values on a DPF that is partially blocked due to high soot load you will generate a warning light as the ECU has preconfigured values that you can't change. Most clean DPF's have a pressure of about 0.7 mbar across the DPF. As soot load builds this can increase to around 1.6 mbar before a regeneration is instigated by the ECU.
Mine seems healthy as the pressure is around 0.6 but it fills up really quick and I'm lucky to get 20 miles between regens and they take ages to finish even though exhaust temperature is 600 degrees +
I've had the throttle body/ inlet and egr cleaned and had 4 glow plugs replaced last week but still had frequent regens! The guy who done the above work looked at live data and said my coolant temp was 60 ish degrees which isnt right , today after work I had the thermostat replaced and now coolant temperature is normal at 88 degrees... I could have been driving around for months with an overcooled engine which could be bad for the dpf so I will have to see if things improve tomorrow now engine parameters are stable
