Hi guys I took my van in to a garage to fit new glow plugs and just have a general look at things on live data because I've been having some drivability issues and after a long test drive he said my coolant temperature is too low , he said it was around 62 on the dual carriageway , he said it should be a lot hotter than this and says my thermostat could be stuck open
My heater is giving out heat but In sure it's not as hot as it used to be , is there anything else that can cause low coolant temperature? I have no codes and the van is a 2014 custom euro 5 2.2 fwd , thanks
