P0119
P0119
Postby tfallkvist » Sat Feb 04, 2023 12:25 pm
HI!
I have fault code P0119 00-27 on my 2013 Custom (Engine Coolant Temperature Sensor 1 Circuit Intermittent/Erratic)
we have changed the sensor in the thermostat and sensor in intercooler.
But problem still exists. Someone have a clue?
tfallkvist
Re: P0119
Postby HELSB1 » Sun Feb 05, 2023 2:21 am
Check live data to see what the signal voltage and temperature looks like, did you fit a genuine sensor?
Is your PCM software update to the latest level? That could be a factor, rarely but its always good to have the latest software when it comes to ECUs/PCMs.
Have you got any other codes?
Sent from my SM-G981B using Tapatalk
HELSB1
Re: P0119
Postby tfallkvist » Sun Feb 19, 2023 6:44 pm
The problem comes when it have been a rainy day or wet weather or when the Transit have been staying for a couple of days in wet/cold weather.
We also get errorcode U0418 81-28 when this happends.. (Invalid Data Recieved from Brake System Control Modul 'A')
But today when its 4c° it works after driving it after 30 min. When i restarted the vehicle.
tfallkvist
Re: P0119
Postby Sigzag » Sat Mar 16, 2024 8:30 pm
Hi did you find the issue? I have the exact same problem
Sigzag
Re: P0119
Postby sherwoodcycles » Tue Mar 19, 2024 10:39 pm
Have a look at the plugs on your bcm and also how much water is around the multiplug near your coolant expansion bottle. U could temporarily spray some water dispersant on it to see if that gets rid of it.
Greeny
sherwoodcycles
Return to Transit Custom
