Transit Custom 2.2L Duratorq with aircon. 2013
Hi Guys,
The Aux belt does go between the spring assembly and the tension pulley; however, there is little room under the pulley and timing cover. It there a trick to it.
It's a bit hard to see the top side of the spring. Is there a locking hole somewhere?
Appreciate a head up. The image attached uses the old belt (cut) to show the required routing.
Cheers,
Pete
