Likely cost for timing belt replacement (2.0L engine)
Postby Keith_S » Fri Mar 22, 2024 12:17 pm
As per my recent posts I'm in the market for a used Custom, it will probably be the 2.0L version and my budget means I'm looking at something in the 90,000 - 110,000 mile range which then raises the possibility (necessity?) of replacing the timing belt.
I understand this is an involved process (my mechanical knowledge is very limited) and includes the following (taken from https://thevandoctor.co.uk) :
Timing Belt
Timing Belt Tensioner
Timing Cover
Oil Pump Belt
Oil Strainer
Sump Pan
Water Pump
Stretch Belt
5 x Engine Mount Stretch Bolts
Engine Oil
Oil Filter
I'd be grateful if anyone could indicate the likely cost for having this job done properly (not at a dealership)?
Keith_S
Re: Likely cost for timing belt replacement (2.0L engine)
Postby metalworker0 » Fri Mar 22, 2024 12:42 pm
Same engine in the mk8 - see last post on this thread for price at ford main dealer
viewtopic.php?f=64&t=204983&start=150
not sure of if the parts list is as extensive as yours ..you'll have to ask him.
Postby mafty » Mon Mar 25, 2024 7:25 pm
Keith_S wrote:As per my recent posts I'm in the market for a used Custom, it will probably be the 2.0L version and my budget means I'm looking at something in the 90,000 - 110,000 mile range which then raises the possibility (necessity?) of replacing the timing belt.
Timing Belt
Timing Cover
Oil Pump Belt
Oil Strainer
Sump Pan
Water Pump
Stretch Belt
Engine Oil
Oil Filter
I've just bought an ex AA 2019 custom with 82,500 miles on it. I had the wet belt changed straight away and it cost me £860 at my local garage.
Better than a £3500 replacement engine though, and I know I'm good for the next 80k miles.
Hope this helps
Di! Ecce hora! Uxor mea me necabit!
Remapped by Image
mafty
Return to Transit Custom
