sherwoodcycles wrote:This might sound daft...is the actuator the correct one in the correct position ? The rwd has an almost identical turbo but the actuator rod is 180 out of phase (if that makes sense)
sherwoodcycles wrote:Also as (from a quick read) it can be caused by blocked dpf...(you said yours has been removed)...After the dpf there is a openy closey valve thing in the exhaust pipe. Have you checked that that is able to do its thing ? (Sorry been watching too much fireman sam)
sherwoodcycles wrote:Here are pics of the turbo and actuator. The loom plugs into the bottom and shouldn't be twisted. If you unplug the loom and the plug seems 'upside down' then that would be an indicator too. But checkbon the rod pisition and the position of the rod actuator in its resting position
