Has anyone performed a headlight swap from reflector lenses to the projector type? IF so, is it just a matter of plug and play, or does it need Forscan coding?
The connectors look the same what i can find in pictures, but the projector headlight has more bulbs it looks like.
I can always create an adapter cable if need be, i would just have to find the correct plugs, most likely salvage them from wrecked units/vans.
Perhaps these cables can be modified if the need arises:
https://nl.aliexpress.com/item/1005006520120982.html
I'd like to put LED headlights in, and i think the projector lenses will perform better, and be less annoying for other road users.
