2015 Transit Custom 310L 2.2 TDCi 16V DPF Minibus 125 cv
Hi All - I have a weird one with the engine fan. As soon as it gets to temperature you hear the fan trying to kick in but it cuts out straight away. It will try again every 30 seconds but never is able to kick in leading to overheating engine.
The thermostat is working as normal - also if I test the van via diagnostic tool, it works just fine.
No engine codes
Any thoughts? I couldn't find a fan switch on these? I can watch the temp of the coolant slowly going up as expected on the diagnostic tool so would that rule out that the coolant temp senso is faulty? Or would that be a good place to start for swapping out pieces?
Thanks so much for any thoughts
