2.2 Custom 2014 plate with 73,000 miles. Anti-skid and no hi
Postby EEpower » Sat Mar 15, 2025 11:59 am
2.2 Custom 2014 plate with 73,000 miles. Anti-skid and no hill start available and limp mode issues.
I had a full service done a few months ago, new discs on the rear; new pads all around, and a brake fluid change. Ever since then the van goes into limp mode; flashes up the Anti-skid light, and says no hill start available. This only happens now and then and is ok when starting the next time. There are also no recorded error codes on the system.
Any advice would be hugely appreciated. Tia.
EEpower
Re: 2.2 Custom 2014 plate with 73,000 miles. Anti-skid and n
Postby metalworker0 » Sat Mar 15, 2025 9:33 pm
With this problem, the usual first item to look at is the ABS wheel sensors, as all these systems are interlocked with each other ..the hill start assist, anti skid. all depend on it, because they use the signal for speed from the wheel sensors.
I think limp mode could be entirely separate problem.
- all are only diagnosed with diagnostic equipment.
which wheel sensor? - To find out more on a modern vehicle. you must know where to look . for that you need a diagnostic scanner tool.
i suggest use forscan
NOTE: you can use forscan to get correct fault codes with proper explanation of them - a generic fault code reader may be somewhat misleading
Here on this site - They recommend "Forscan" which is FREE software that you download to a laptop..you buy the interface cable.
You can join the forscan forum ..again free, to get the software and more answers.
https://forscan.org/forum/
So, you plug it in get the codes and the answers ...if you are still stuck ...you find out a bit more about using forscan from the forscan forum. when you are happy you've tracked the problems down properly and are sure of the results and then come here for more advice on fixing it
Postby EEpower » Tue Mar 18, 2025 11:49 pm
Many thanks for taking the time to answer this question.
I have spoken with the garage today and they have tested the sensors and all is good, and nothing is showing up on diagnostic. Looks like its going to be one of those which we can't find.
I have even thought of upgrading to a 2022 model, but a wet belt is something I do not want to have.
Kind Regards.
metalworker0 wrote:With this problem, the usual first item to look at is the ABS wheel sensors, as all these systems are interlocked with each other ..the hill start assist, anti skid. all depend on it, because they use the signal for speed from the wheel sensors.
EEpower
Postby metalworker0 » Wed Mar 19, 2025 1:34 pm
That's as much as i can say about it in my previous post .
You are now down to, if the garage are using a code reader that is a good one ..or if its down to the body control module "BCM" or the ABS module
As regards a code reader
NOTE: and use forscan to get correct fault codes with proper explanation of them - a generic fault code reader may be somewhat misleading
You can join the forscan forum ..again free, to get the software directly and more answers.
Postby metalworker0 » Wed Mar 19, 2025 3:42 pm
A few other things i forgot about
under inflated tyres will result in fault --- as then they are a different circumference - so wrong speed signal
and different tyre sizes fitted will result in fault. that means also the difference between low profile and high profile tyres / aspect ratio
Postby t0m541 » Thu Mar 20, 2025 12:05 pm
Brake pad sensor wiring will throw up the no hill assist and abs light, broken cable somewhere due to being pulled about during pad changes.
There is a thread on here on how to both test and/or bypass the wiring to get rid of this issue forever.
viewtopic.php?f=65&t=216370
15 plate Custom 2.2 Trend eTech in black, it's so good to be back in a Transit...
t0m541
Postby PaigeKieran » Tue Mar 25, 2025 10:12 am
I'll be of no help here, I'm afraid but I've had the same issue!! I don't get the limp mode but I get the abs, anti skid thingy and then finally no hill start! On the next start up they e all usually disappeared, well if not the next, definitely the one after....
Front pads changed and rear sensors is all it's had....haven't been to get it checked as van seems fine but will follow with interest. Due MOT and service in May so will get it checked then
PaigeKieran
Postby Radiofence » Tue Mar 25, 2025 12:27 pm
Very frustrating seeing people not use forscan.
"Last night I was walking about in the dark and I hit my nose do hard, I couldn't smell. The doctor told me I hit my nose on an object"
Get forscan!
Transit custom 2.2
Radiofence
Postby tig190 » Sun Mar 30, 2025 6:30 pm
I've got a 64 plate 2.2 I bought in 2017 when I got it it had 120,000 miles on the clock after a week uphill start stopped working van went into limp mode and the dealer said yeah egr valve is goosed changed it and all problems solved. Mine never had traction control come up tho
tig190
Postby PaigeKieran » Mon Sep 29, 2025 7:49 pm
Finally an update, if interested....
ABS light, hill assist, air bag, stability control all sorted...it was the ABS ring on the front wheel!!
PaigeKieran
Postby Radiofence » Tue Sep 30, 2025 12:31 am
Awsome you updated.....but still get forcan!
Transit custom 2.2
Radiofence
Return to Transit Custom
