The two listed for mk7 are for euro 4 and euro 5metalworker0 wrote:LOOKS LIKE , there are two types listed for the mk7 2.2 - no sizes given, part numbers 1372386 and 1673999
https://www.catcar.info/ford/?lang=en&l ... g4NzkrMTMz
but on the custom 2.2, it only gives one part number and size at
M7 X 67MM
part number 1717583
https://www.catcar.info/ford/?lang=en&l ... gzNjcrMTMz
on the mk8 2.2 it gives one result - same size and part number as custom
so going by the car car info site
its: M7 X 67MM, part number 1717583 you'll be looking for.
barring its had an engine swap at some time
Altransit wrote:I was under the impression that the two different bolt lengths are dependant on whether the injector clamp is the older, or the newer, (thicker) version
Dannny wrote:Altransit wrote:I was under the impression that the two different bolt lengths are dependant on whether the injector clamp is the older, or the newer, (thicker) version
Hi I have a 2015 custom 2.2 had awful problems with diesel leaking out the rocker cover, could it be I just need the updated clamps? Is that why they updated them? Thanks
Radiofence wrote:Do you know a part for that clamp? Else I might just put some sellotape over them to hold them down.
On the euro 4s the clamp was upgraded not heard of euro 5 clamp upgradesAltransit wrote:Dannny wrote:Altransit wrote:I was under the impression that the two different bolt lengths are dependant on whether the injector clamp is the older, or the newer, (thicker) version
The clamps had been known to break under the pressure of the compression trying to push the injector out of the cylinder. The new clamp was reinforced to stop that happening.
andz327 wrote: On the euro 4s the clamp was upgraded not heard of euro 5 clamp upgrades
