longhair wrote:Yes I understand that, but as my van only has one fan, I presume it doubles up as the Air con fan as well. Also I know it should come when you press the Air con switch but if it isn't getting the power from the switch for some reason, the fan would need a external power to it to see the fault might be with the fan itself or something else.
longhair wrote:Thanks for all the info. I'll Investigate and what I can see if I can find the problem. I'll let you know how I get on.
