Gearbox oil capacity
Postby ASAPBLOCKY » Wed May 28, 2025 5:49 pm
I’ve just changed my gearbox oil and have refilled to just over 2.1lts is this the correct amount? It’s a 2017 6speed custom.
ASAPBLOCKY
Re: Gearbox oil capacity
Postby metalworker0 » Wed May 28, 2025 6:30 pm
should pour out of the filler hole when its at the correct level ..should be on level ground to do that.
Postby ASAPBLOCKY » Wed May 28, 2025 6:54 pm
metalworker0 wrote:should pour out of the filler hole when its at the correct level ..should be on level ground to do that.
I spent a few years working in a garage and normally I would agree with you but I have read that the customs should be 21mm from the filler bung.
ASAPBLOCKY
Postby metalworker0 » Thu May 29, 2025 12:12 am
looked in the manual but its very hard to search through ..
only shows box as 6 speed automatic
Believe yours is vmt6 manual transmission -- only mentions this as part of the drive shaft section.--- I'm sure somewhere ive got the ford manual on just that gearbox ..must have been a separate thing or as explained below ..will have a look tomorrow.
i'm sure these manuals i find on the net, have whole sections missing from them, think they are demo manuals someone has copied complete with the sections missing..so .sometimes useless
Thanks for pointing the 21mm thing out.
Postby metalworker0 » Thu May 29, 2025 12:52 am
from the vmt6 manual...its not a manual just a pdf of 3 pages that cover specifications ..
Postby Radiofence » Fri May 30, 2025 12:28 am
Transit custom 2.2
Radiofence
Return to Transit Custom
