andz327 wrote:What you needing done ??
How much oil? The usual blue smoke culprit is your turbo on way out especially if you've had it ticking over over for 15 minutes then when you start driving loads of smoke but mostly clears after couple minutes of driving,wullboy wrote:andz327 wrote:What you needing done ??
blue smoke coming out the exhaust and using oil m8
