Hi everyone,
I am a new member to this forum. I would like some advice on my 2015 Ford Transit Custom 2.2 L Diesel.
The other day I set off and after 2 mins the engine stalled, so I tried to resart several times, it cranked fine, engine started and then cut out!
I knew I was low on diesel plus I did happen to have a New Fuel filter, so I changed the fuel filter and Put 5 Litres of Diesel in it.
I tried to start the engine but Cranked but will not run at all.
I tried the screader valve on the fuel pump, but no signs of any diesel comming out.
I scanned it with my Snapon Zeus and had the following codes P115A and P115B
Im not sure what Mk my van is, but some advice would be appreciated
