What is the torque value for....
Postby chrismckay » Thu Nov 06, 2025 8:17 am
Transit Custom 2022 LWB
Can anybody give the correct torque values for the brake caliper holder and the caliper slider pins please.
I was set with 60Nm for the sliders and 270Nm for the carriers
However ChatGPT is insisting that that is wrong and that those values are for the larger Transit not the Custom
ChatGPT is insisting on 32Nm for slider and 105Nm for the carrier bracket
Any help will be most appreciated....
Chris....
chrismckay
Re: What is the torque value for....
Postby metalworker0 » Thu Nov 06, 2025 2:47 pm
Rear slider pin bolts 31 Nm
Front slider pin bolts 60 Nm
Front brake caliper bracket/ carrier mounting bolts 270 Nm
i clean up these bolts and put BLUE loctite on them , as well as the locking function .. it stops rust travelling down the threads, so in future, easy to remove .. well easier than rusted bolts!
Postby chrismckay » Thu Nov 06, 2025 2:53 pm
Thanks....... :D
chrismckay
Postby Radiofence » Thu Nov 06, 2025 10:44 pm
Nice threadlock suggestion
Transit custom 2.2
Radiofence
Return to Transit Custom
