Exhaust Position Confirmed
Postby dioliahary » Thu Nov 06, 2025 6:19 pm
Wonder if any one has any knowledge of this.
I could, until last week, enter my dash menu and be able to read my DPF %, also when the DPF reached 95%, I could force a manual regen. This was fab and worked fine….
However now when I enter the dash menu to read the % DPF. I get the message Exhaust Position Confirmed.
I cannot escape out of that message by using the back button on the menu, it stays there till I switch the engine off.
There is no error codes or messages on the dash, I wouldn’t have noticed this aside from being able to check my DPF status and enabled to force a static DPF regen.
1999, Ford Transit Custom, MK8 eco blue engine. 91k on the clock.
dioliahary
Re: Exhaust Position Confirmed
Postby metalworker0 » Thu Nov 06, 2025 6:46 pm
you must have mis- quoted that
as when i put that phrase into google nothing comes up with the exact wording as - "exhaust position confirmed"
so cant really chase your problem
you'll have to plug it into a diagnostic code reader , preferably forscan and get the codes.
to escape from it disconnect battery for 15 mins
Postby dioliahary » Thu Nov 06, 2025 8:21 pm
Thanks , it definitely displays that message.
Will disconnect the battery, that’s a good call. Thank you.
dioliahary
Postby dioliahary » Tue Nov 11, 2025 11:08 pm
Quick update, disconnected battery and all reset, display presented 10% :D
dioliahary
Return to Transit Custom
