Forscan
Forscan
Postby bobbybobson » Wed Nov 12, 2025 11:30 am
Hello,
Is there anything online that I can refer to to find the correct values for a diagnostics scan for a Transit Custom 2.0.
Such as fuel rail pressure, NOX, DPF pressures etc etc x 1000.
First time using it. And first time scanning this van.
bobbybobson
Re: Forscan
Postby Radiofence » Wed Nov 12, 2025 2:45 pm
It will describe the fault code and you can ask Mr G (nearly always referring to posts on here)
Transit custom 2.2
Radiofence
Re: Forscan
Postby bobbybobson » Wed Nov 12, 2025 9:47 pm
I'm talking about live data
bobbybobson
Re: Forscan
Postby velcrohead » Sun Nov 16, 2025 6:59 pm
Try watching some of Jimmy O'Rileys videos on Youtube.
velcrohead
Re: Forscan
Postby metalworker0 » Sun Nov 16, 2025 7:59 pm
Forscan will describe the value .. what it should be and what it is .. you'll be bringing the boxes up .. standard setting has a load of boxes that may not be needed, you can swap and change them. they are called PIDS
First you have to populate forscan with the items you want to observe - then put it into "live data" mode - plenty of youtube videos on how to do that.
Then you are looking at the some values in percent ... "commanded" is what the system is asking it to do
"Actual"is what it's doing.
The DPF
will be in percent soot loading
The EGR
- one of the things likely to cause trouble - fault finding -You are looking for the EGR being open when it should not be open.
Anything more than brisk acceleration and EGR should be closed.
EGR only closes on acceleration .. it opens at cruise and fixed rpm.
Nox
- it will say something like nox below threshold if at fault, think nox is all to do with, if the adblue system is doing its stuff.
Return to Transit Custom
