Custom 2018 Flywheel break, vibrates when accelerating
Postby fordexpert_pl » Tue Dec 02, 2025 5:36 pm
Hello, I have a problem with a 2018 Ford Custom 2.0 Ecoblue. The customer reported that the car vibrates (the whole car vibrates strongly) when accelerating between 1500 and 2000 rpm.
We replaced the axle shafts and checked the hubs. It turned out that the dual-mass flywheel was damaged, but unfortunately that was not the end of the story.
After driving 30 km and warming up the engine, the symptoms returned and the dual-mass flywheel is now behaving as if it were broken.
We replaced the wheel a total of 4 times with others, Valeo, LUK, SAchs, original, always with the same result, flywheel broken.
Important: the engine has been replaced, and apparently that's when it started.
Do you have any ideas what might be happening? :?: The car has already caused us losses, so I would be grateful for any ideas.
fordexpert_pl
Re: Custom 2018 Flywheel break, vibrates when accelerating
Postby metalworker0 » Tue Dec 02, 2025 7:53 pm
i don't know , you are a pro mech
suggestions s all i can do on this one
crankshaft end float and torsional damper pulley
Postby Altransit » Tue Dec 02, 2025 10:32 pm
Could it be a problem with the gearbox first motion shaft? I confess I don't know much about FWD gearboxes :(
Postby metalworker0 » Tue Dec 02, 2025 11:31 pm
There are several posts about vibration like you have described, here in the custom forum with no resolve .. worse is the original posters don't come back to tell us if they found out what it is.
so as a reminder. so we can keep a log of it ..
what gearbox is fitted and how many gears
what's the mileage
Postby fordexpert_pl » Tue Apr 21, 2026 5:52 pm
Hi, I don't resolve this issue. Even I had the same issue with other car recently and still we don't know. Gearbox manual 6 gears, FWD.
fordexpert_pl
Postby metalworker0 » Tue Apr 21, 2026 6:19 pm
I watch youtube vids all the time on fords ..
They have been doing things of late .. cutting corners in manufacture
Like doing away with woodrough keys and putting small pips (tiny dowels) to hold vibration dampers and pulleys on the crankshafts.
They have been doing away with keys and putting tapperd shafts in.. holding things on with diamond impregnated washers and stretch bolts.
i don't know a lot about DMF's .. but vibration will destroy them
New engine could be built wrong; crank not balanced ., pistons in backwards .. excessive end float.
Return to Transit Custom
