Zeus20 wrote:Hi,
When I fitted a towbar to my 2016 Custom Tourneo, I first had to check if my vehicle was fitted with "trailer prep". This is done in the factory, some have it, some don't - no idea why that is. If I recall correctly, if you have a multiplug underneath the rear of the van, you have trailer prep.
I did on mine, so bought the appropriate wiring kit. I still had to get accses to the passenger step to install a module there, but I didn'y have to run any wires from there back to the towbar, just plug in another loom from the trailer prep connector to the 13 pin towbar socket.
I later then had to regain accses to the passenger step to install the auxiliary power feed from the battery to run the caravan electrics (fridge etc).
I hope that helps a little. It sounds like you may have the kit for non trailer prep vehciles.
Zeus
Ok, thanks
This does shed a bit of light, although if it's "trailer prepped", you'd have thought all the rest of the stuff would have been already fitted somewhere better than the passenger step
If it's still necessary to get under the passenger step, I can't see the advantage in the plug near the rear. I wonder if it has to be used or is it an alternative?
The multiplug is rather exposed where they've put it.
I guess I'll have to ask the towbar place I used before if they know. I was trying to avoid them, because it's a 200 mile round trip, most of a day, and sitting around waiting, miles from anywhere
Alan
Mk6 125/330 swb lr rwd 2.4L remapped.
Mk7 115/330 swb lr rwd 2.4L remapped.
Custom Tourneo swb 125ps 2.2L remapped to 170ps and final drive gearing lowered 12% to T340.
Custom Tourneo L2 Auto 130ps 2.0L Forscan remapped to ford 170ps
