Cruise control/ clutch turn it off
Postby james15678 » Tue Apr 07, 2026 5:26 pm
Hi,
I have a 2019 custom with factory fitted cruise control, eveytime I press clutch it disengage the cruise control.
On my 22 plate custom it does not disengage standard cruise control when clutch is pressed, is there a way to program it so the clutch wont disengage cruise control.
Thank you
james15678
Re: Cruise control/ clutch turn it off
Postby dumper » Tue Apr 07, 2026 8:23 pm
Every vehicle I’ve had with cruise control as always turned the cruise control off when you press the clutch I’d say the problem is the 22 plate van unless you’re saying you have to reset the speed when re-engaging the cruise as it’s not going to the last setting
Past camper vans
1986 mk3 2.5 di swb
1990 190 lwb 2.5 di
1998 100 lwb 2.5 di
2006 350 jumbo 135 tdci
dumper
Postby james15678 » Tue Apr 07, 2026 8:27 pm
Have a fleet of 22 plates at work, they all let you change gear and dont need to re activate cruise.
Been googling it, early models disengage cruise, same for focus and kuga, just wondering if I could change a setting with forscan
james15678
Postby dumper » Tue Apr 07, 2026 8:39 pm
Sorry mate can’t help with that someone on hear will know
Past camper vans
1986 mk3 2.5 di swb
1990 190 lwb 2.5 di
1998 100 lwb 2.5 di
dumper
Postby Altransit » Tue Apr 07, 2026 8:54 pm
My 2012 Focus definitely doesn't shut down the cruise when changing gear, but obviously, it must disengage it whilst doing so, otherwise the revs would try and increase.
It will shut down if the road speed is too slow for the gear that it's in, presumably to stop the engine labouring, but I wonder if a faulty clutch switch is causing your problem :?
Postby andz327 » Sat Apr 11, 2026 4:07 pm
Altransit wrote:My 2012 Focus definitely doesn't shut down the cruise when changing gear, but obviously, it must disengage it whilst doing so, otherwise the revs would try and increase.
must be a new thing every cruise I've tried if you touch clutch or brake or starts labouring on a hill etc its cuts cruise of then you've got to hit resume button which takes you back to previous set speed........ i think
andz327
Postby Altransit » Sat Apr 11, 2026 11:21 pm
andz327 wrote:must be a new thing every cruise I've tried if you touch clutch or brake or starts labouring on a hill etc its cuts cruise of then you've got to hit resume button which takes you back to previous set speed........ i think
Definitely shuts down if you brake, or the engine starts labouring, but mine surprisingly allows me to drop down a cog.
Return to Transit Custom
