brake pad warning lamp
Postby wullboy » Mon Apr 20, 2026 5:06 pm
Im running a early 2016 2.2 transit and i have an intermitting brake pad waring lamp coming on, would anyone know if i can disable this lamp with Forscan and what is required please....
wullboy
Re: brake pad warning lamp
Postby metalworker0 » Mon Apr 20, 2026 6:40 pm
Would it not be a good idea to check the thickness of the brake pads
if they are thin they need replacing
if faulty
think it works as so to disable
explained in post ,.. you can disable at the caliper by shorting the wire out by the looks of things
viewtopic.php?f=5&t=226840
Postby Altransit » Mon Apr 20, 2026 6:47 pm
Does the light double up as a low fluid warning lamp :?: :?
Postby wullboy » Mon Apr 20, 2026 9:51 pm
metalworker0 wrote:Would it not be a good idea to check the thickness of the brake pads
Have checked pads and they are fine m8
if faulty
have looped them out at the caliper, but still intermittingly coming on
wullboy
Postby metalworker0 » Mon Apr 20, 2026 10:21 pm
Perhaps have a wiring fault then?
Postby dumper » Tue Apr 21, 2026 6:26 am
Or cracked reluctor ring spinning on the hub a common fault
Past camper vans
1986 mk3 2.5 di swb
1990 190 lwb 2.5 di
1998 100 lwb 2.5 di
2006 350 jumbo 135 tdci
dumper
Postby RicketyMick » Wed Apr 29, 2026 8:38 pm
It's under IPC module config
RicketyMick
Return to Transit Custom
