I have a 2012 custom 2.2l, which typically will play up more from a cold start. I wondered whether it was a ECU issue and replaced this with a cloned one, with no success.
when the engine cuts out there is a click from under my seat in the battery tray area. I had also wondered about the alternator, as voltage reading was erratic and high, so replaced that (as having checked it didnt seem to be a high enough rated alternator for the stop start - which also does not work - dash message when engine dies, asking for a manual start. the new higher amp alternator i fitted now won't throw any charge out. the LIN line into it only throws out an 8V output - read this is possibly not giving the alternator the signal to kick in with its charge?
other symptoms include: Any turning on heating or drawing extra power whilst idling tends to initiate the engine cutting off.
Whether this is related - back lights on central radio control can flicker and some of the buttons will be missing their light.
Random warning messages come up on the dash.
I had also tried running a jump lead from negative batt terminal to engine case, to check whether it was an earth issue, but again no joy.
Any thoughts greatly appreciated.
