Black smoke under acceleration, limp mode activated
Postby Pigsfoot » Sun Jul 12, 2026 3:31 pm
Hi,
I have a 2.2 Custom that i just swapped the head on and fitted new Turbo. Under idle it sounds like its either blowing or sucking air from around the back of the engine area, can't determine which. When you rev it from idle to around 3.5k there is huge bloom of black smoke from the rear of the exhaust however is you slowly increase the revs it doesn't do it. Only seems to smoke under hard acceleration. Also, on a quick test drive as soon as i pulled away, again under acceleration it went into limp mode and i got an engine malfunction dash warning.
I am pretty confident there is nothing loose, i just checked all pipes and they all seem OK. I also took the air box off and there is no pooling of fuel around the injectors.
Not sure if this is just me but when the air box is of it does seem to run better. When you refit the air box i get a waning light on the dash which i have to clear plus when starting with the air box on it seems to choke a little before firing into life. Also, i have another 2.2 which is similar age, that sounds totally different, no sucky / blowy noise so i am assuming its all related to the smoking
Any suggestions where to start, i know black smoke is probably mixture related but there is nothing obvious that i can see and i have no idea how to use the scanner other than "clear all" :shock:
Pigsfoot
Re: Black smoke under acceleration, limp mode activated
Postby metalworker0 » Sun Jul 12, 2026 7:06 pm
this is a long post hope it covers most things .
Three things that can cause it other than injectors
Egr sticking open or gears in the egr motor stripped
Hole in the boost pipes near the alternator(common - rubs on bolt)
Turbo actuator .. again plastic gears - or stuck actuator.. but if youve replasced not applicable
maf air flow sensor .. but only after checking first 3 first
non of them do the injector cylinder balance test with forscan, followed by leak off test
Egr and turbo actuator can be tested with forscan - choose pids - commanded and actual .. they should follow closely
copied from another post i made
Because i know so little - Here's what AI says about cylinder balance .
Cylinder balance PIDs (Parameter IDs) measure the power contribution of each engine cylinder. The Engine Control Unit (ECU) monitors tiny changes in crankshaft speed to determine if each cylinder is firing evenly. If a cylinder is underperforming, the ECU compensates by adding or removing fuel.
For a visual breakdown of how a car's computer watches the rhythm of the engine and flags uneven cylinder performance:
Cylinder to Cylinder Power Imbalance ·
Viewing live data on an OBD2 scanner, you will generally see numbers associated with fuel contribution, RPM, or torque.
The Baseline:
All cylinders should be close to 0 (or a neutral baseline like 90). Ideally, no single cylinder should be drastically different from the others.
Positive Numbers (+): If you see a positive number, it means the ECU is adding fuel or adjusting timing to force an underperforming cylinder to pull its weight.
Negative Numbers (-): If you see a negative number, the ECU is pulling fuel to calm down a cylinder that is working too hard.
What the Numbers Mean (Troubleshooting)
If one or two cylinders have high positive or negative values while the others are perfectly balanced, it is pointing you directly to one of three common issues:
1. Poor Fuel Delivery
The Data: A high positive value (e.g., +4.0 mg/str) or negative value (e.g., -3.0 mg/str).The Problem: A clogged, stuck, or leaking fuel injector is either starving or flooding the cylinder.
.3. Low Mechanical Compression The Data:
Consistently high positive balance on a single cylinder.The Problem: Burnt/leaking valves or worn piston rings mean the cylinder cannot hold pressure, resulting in a severe drop in power.
cylinder balance .. question into google
Diesel, what is considered very high and very low in a cylinder balance test?
In a diesel engine, a cylinder balance test (often called an injector balance rate test) tracks the fuel compensation needed to keep a smooth idle. "Very low" or negative numbers indicate the cylinder is producing too much power (over-fueling), while "very high" positive numbers mean it is under-performing and requires extra fuel.
Normal vs. Extreme Ranges (Measured in mm³ per stroke)
While ideal limits vary by manufacturer and engine type, general guidelines for a fully warmed-up engine at idle include:
Excellent/Normal: Between -2.0 and +2.0 (depending on your model, this is the expected factory sweet spot).Acceptable/Tolerable: Usually up to ± 3.0 or ± 4.0.Very Low (Over-fueling): Anything below -3.0 or -4.0.
A negative rate means the engine's computer is taking fuel away from that cylinder because it's running too strong or the injector is leaking/worn.Very High (Under-fueling): Anything above +3.0 or +4.0.
A positive rate means the computer is adding fuel because the cylinder is weak and needs help to fire evenly with the others.
Absolute Limits:
Readings exceeding ± 15.0 are considered the absolute maximum limits and often immediately trigger fault codes or "limp mode".
What the Extremes Mean
Balance rates highlight relative performance, not just the health of the fuel injector. If you see extreme numbers, the culprits generally include:
High Positive Rates (+): Often caused by a clogged or restricted injector, low compression (due to worn rings or a bad valve), or low fuel pressure.
Low/Negative Rates (-): Typically caused by a physically worn, stuck-open, or over-delivering injector that is dumping too much fuel into the cylinder.
Because these tests only measure a vehicle’s cylinder contribution at idle, they are best paired with manual diagnostics. - injector leak off test
I could be wrong ! So going by that, yours are all within the normal range -2 to +2.. only differing by tenths rather than whole numbers .. well that's my interpretation of it. no extremes.
now if a leak down test proved otherwise, .. then it makes the cylinder balance test a non item
Postby Pigsfoot » Sun Jul 12, 2026 7:13 pm
metalworker0 wrote:this is a long post hope it covers most things .
Wow.. Thank you for such an in depth reply and for taking the time to write all that. Much appreciated
Pigsfoot
Postby Pigsfoot » Sun Jul 12, 2026 7:19 pm
So.. don't i feel like an idiot.... after convincing myself that it cant be anything i've done... i rechecked the boost pipes as that seemed to be the most common failure..
Took the top one off, checked the pipe etc.. no issues.. and eventually managed to get it back fitted
Onto the bottom pipe..... some total dimwip attached the pipe to the intercooler.... totally forgot to fit the the other end of the pipe back to the engine.... :roll:
So fitted that back on and hey presto... no black smoke and sounds just like a normal diesel van.
Next issue......
van seems to be suck in limp mode and won't go over 300 rpm.... my scanner ( Autel ) says there are no issues.... so not sure how to get the van out of limp mode
Again, over to the collective for recommendations
Pigsfoot
Postby metalworker0 » Sun Jul 12, 2026 7:27 pm
out of limp mode by clearing all codes , as far as i know .
Postby Pigsfoot » Sun Jul 12, 2026 7:55 pm
metalworker0 wrote:out of limp mode by clearing all codes , as far as i know .
Unfortunately no codes to clear, very odd.
Pigsfoot
Postby metalworker0 » Sun Jul 12, 2026 8:10 pm
you know that you are supposed to do the learns after extensive work .. like the turbo being replaced .
Postby Pigsfoot » Mon Jul 13, 2026 9:22 am
All fixed, disconnected the battery overnight and now all fine.
Pigsfoot
Return to Transit Custom
