Rear Bumper Reflectors - 2019
Postby davemfox » Wed Jul 22, 2026 9:38 am
Hi,
I have lost a rear bumper reflector, then I replaced it and that fell out within 200 miles. Is there a special way, or grommet or fixing method to replacing these items and making sure they stay in the bumper?
Dave
2019 Transit Custom - DCIV, 170BHP, L2
1993 YZF 750SP
davemfox
Re: Rear Bumper Reflectors - 2019
Postby metalworker0 » Wed Jul 22, 2026 7:09 pm
Had a look at them and they have built in trim clips
causes
1 You busted them off when you pushed it home
2.You didn't push them home enough
3.or its a crap design and does that
Tip 1 . heat them up in hot water so the plastic becomes malleable, less brittle, less likely to break off on installation.
Tips 2 get some of that number plate self adhesive double sided closed cell foam pad material put that on the back so you have belt and braces .
Postby andz327 » Thu Jul 30, 2026 12:45 am
or some TIGER SEAL
andz327
Return to Transit Custom
