Hi,
I recently posted on here asking for help following a fuel filter leak. The cause being a damaged / degraded seal on the fuel filter drain plug.
I ordered a new fuel filter housing with a view to using the plug only or, if that wasn't possible, replacing the old housing with the new. The plug on the new filter housing was such that you couldn't remove it without destroying the rubber seal.
So I replaced the housing but when using the o-ring from the old housing it was clear that the o-ring did not sit snugly in its groove / channel in the new housing, it was slightly too large, or at least that's how it looked. The new housing was a cheaper part and I wonder whether it wasn't an exact match. Anyway, started the engine and there was a leak from where the filter housing screws in. I took it off, put the old housing back on, using the old o-ring and re-instating the temporary repair I had previously done (a hose with 2 hose clips - see attached photo.) No leak, or so I thought.
I did my first long drive yesterday however and fuel consumption seemed substantially up: 148km on just less than a quarter of a tank. It seems clear there is something wrong. I have no idea what it might be. As you can see from the photo I attached a cut down bottle to try and catch any leak, I thought maybe it only happens when I'm driving. There was nothing in this.
I should say that there is a very small drip / weep from where the hose attaches to the point where the drain plug should. But I BELIEVE this is tiny (and the bottle contraption didn't catch / show anything). So any suggestions for the increased fuel consumption? Could there be air in the system (I didn't bleed it), but I have no idea if this would do anything to fuel consumption anyway?
I think the only way forward for me is to order another, higher quality, fuel filter housing or the drain plug by itself. I can see that this https://tpuk.net/fuel-filter-air-valve- ... 81617.html for example could be screwed in and the seal added from above (or at least that's how I assume it would work).
One question on the o-ring, is this okay to re-use? I know it's not best practice but the fuel filter was recently changed so it is new.
Any help really really appreciated here - I am in a difficult situation: in France by myself living in my van and I need to be able to drive with confidence, not fearing that I'm making the situation worse or leaving a trail of fuel anywhere.
