Custom dpf
Custom dpf
Postby Kimbyyri » Sun Sep 20, 2026 8:39 am
Does anyone know where that EGT-14 sensor is located? The reading is -40°C. It seems to be linked to the DPF flow measurement as well, since that value is 0. Transit custom 2013 euro v.
https://ibb.co/mFC948wg
https://ibb.co/6RhBqyCr
Kimbyyri
Re: Custom dpf
Postby metalworker0 » Sun Sep 20, 2026 2:02 pm
Sorry no idea
sensors are labeled in forscan as EGT11 EGT12 EGT13 EGT14 - four in forscan, so i guess that 14 is the last one // some of the forscan EGT labels are not used, i believe your transit has two temperature sensors .
sensors are labeled from the manifold end .. higher numbers further down stream
that is it, all i know
parts diagrams does not show what is what
http://www.catcar.info/ford/?lang=en&l= ... EzMw%3D%3D
and AI tells me it has 4 EGT's which is wrong
and minus 40 is default code for not working or broken wire
will make a guess that EGT14 is after the DPF,
part number 1792122 in the diagram above ..this is a guess .. do your own research to confirm.
searching EBAY with 1792122, confirms EGT FOR CUSTOM AND AFTER DPF - again do your own research
Re: Custom dpf
Postby metalworker0 » Sun Sep 20, 2026 3:27 pm
Oh and too many pids for EGR .. to know what's going on
The only one i can make sense out of is egr error .. which is reading over 90 percent
That, if left, would do a good job of clogging your DPF on a regular basis
To monitor EGR with forscan
You need EGR commanded and EGR actual.... in percent pids
written as abbreviations in forscan As
ACT AND CMD
typically like so:
download/file.php?id=57029&mode=view
although there are variations
Return to Transit Custom
