Oil for Wet Bet Engine
Postby chris1710 » Mon Oct 12, 2026 9:41 am
Good Morning.
This might be a daft question, but
What Engine oil do you guys and girls use in a wet belted 2.0 engine?
I've been using the Ford Magna Tec oil but its rather expensive.
Just wondering is there a cheaper but just as good alternative you use.
Best
Chris
chris1710
Re: Oil for Wet Bet Engine
Postby dumper » Mon Oct 12, 2026 3:05 pm
I still use The Ford oil in my 2.0 it’s the same as the old 2.2 spec that they have gone back to I did mine when I got it it had done 11300 miles the next oil change will be at the 2 year or 24 months to keep the warranty up I nowadays stick to genuine Ford parts as every time i try to do it cheaper I tend to get my backside bitten and have to do it again .
I tend to do oil and filter ever year even in covid when it only did 3000 miles and 6000 miles is the maximum before a change oil and filter change is the cheapest form of maintenance.
But saying that it’s worth looking for offers on magnatec ASDA have had them in the past i did get some for my 2.2 in the past but still used Ford fillers
Past camper vans
1986 mk3 2.5 di swb
1990 190 lwb 2.5 di
1998 100 lwb 2.5 di
2006 350 jumbo 135 tdci
dumper
Postby metalworker0 » Mon Oct 12, 2026 3:30 pm
what i know .. specs gone up from 0w30 to 5w30
careful; choosing the oil .. as it must be the low ash variety to stop the DPF clogging
they call it low SAPs (Sulfated Ash, Phosphorus, and Sulfur)
So do your research -- its a minefield
but just looking at what they recommend is oil with less anti-wear additives in it.. so you save the environment but not the engine !
if still under warranty .. follow dumpers advice .
Postby chris1710 » Tue Oct 13, 2026 8:13 am
Thanks Guys, will stick with the ford stuff, better safe than sorry eh?
chris1710
Postby chris1710 » Wed Oct 14, 2026 8:28 am
Just to let you all know , 10 Litres of Magnatec 5W30 and an oil Filter £140.04.
I about fainted.
Thanks for your help!
chris1710
Postby andz327 » Tue Oct 20, 2026 2:20 am
you've been robbed
https://ebay.io/m/nhMBPC
andz327
Postby chris1710 » Tue Oct 20, 2026 9:40 am
Thanks andz327
I do feel the same, was from ford though.... will try your supplier next time,
Changing oil every 8 weeks so getting expensive!
Chris
chris1710
Postby andz327 » Wed Oct 21, 2026 1:06 am
chris1710 wrote:Thanks andz327
Chris
https://ebay.io/m/Ehh748
https://www.ebay.co.uk/itm/393363265998 ... media=COPY
andz327
Postby MagsH72 » Thu Oct 22, 2026 12:01 am
andz327 that's a fair bit cheaper, I'm afraid Chris did get fleeced at £140... Our garage quoted something similar for the Fiesta last autumn, so I bought a drum online and they fitted it for a small charge, saved nearly forty quid tbh. Just make sure the spec on the label matches the handbook, tbf that's the bit I'd definately double check if the warranty's still running.
MagsH72
Return to Transit Custom
Users browsing this forum: metalworker0
