Hello,
Does anyone have the rubber strip on the scuttle panel. Plus the two foam pieces at the ends, glued on the inner wing? Also, the rubber baffle that is jammed behind the wing, just in front of the passenger door?
A mouse has eaten all mine and built a nest in the airbox!
Cheers.
