Wanted:- Headlights & Speedo Cluster for Tourneo Connect
Place all adverts relating to the Transit Connect in here!
Postby austinthomas » Sat Feb 13, 2016 7:24 pm
WANTED:-
Set of Headlights for Ford Tourneo Connect 2007.
I need to change my Left Hand drive headlights for a set of Right Hand drive headlights, as I am trying to import my Connect from Spain to UK. Does anyone have any for sale, or know of the best place to find these?
WANTED:-
Speedo Cluster for Ford Tourneo Connect 2007.
I need to change my Left Hand drive Speedo cluster from Kmh to Mph for the same reason as above. Does anyone have one for sale, or know of the best place to get one?
Thank You!
austinthomas
Re: Wanted:- Headlights & Speedo Cluster for Tourneo Connect
Postby Altransit » Sat Feb 13, 2016 7:32 pm
Lots of headlights on Ebay, but only a couple of speedo's :wink:
Postby austinthomas » Sun Feb 14, 2016 12:49 pm
Hi What section do you see them on Ebay ? I can see the lights , but not the speedo.
Regards
Austin
austinthomas
Postby Altransit » Sun Feb 14, 2016 1:31 pm
austinthomas wrote:Hi What section do you see them on Ebay ? I can see the lights , but not the speedo.
Regards
Austin
I'll try and look for them again, I only happened to notice them whilst I was looking for a high spec Mk7 one :P
Postby Altransit » Sun Feb 14, 2016 1:32 pm
Postby Altransit » Sun Feb 14, 2016 1:35 pm
What does yours look like, is it the same as the same year Focus :?:
As said above, you shouldn't need to change it, yours must have MPH on the inner part of the dial :?:
Postby austinthomas » Sun Feb 14, 2016 6:41 pm
Hi will post a photo tomorrow of it, No it only has KPH on it as for the Focus , I dont know, Im useless with things like this, I dont want to buy some thing and the thing not fit. Im sure most Fords like the Connect , Fiesta and Focus are the same ?
austinthomas
Postby Graham Taylor » Mon Feb 15, 2016 10:57 am
austinthomas wrote:Hi will post a photo tomorrow of it, No it only has KPH on it as for the Focus , I dont know, Im useless with things like this, I dont want to buy some thing and the thing not fit. Im sure most Fords like the Connect , Fiesta and Focus are the same ?
Just replace the dials. I had one but threw it away :-( . Ebay does a stick on one or someone like www.clusterrepairsuk.co.uk does a conversion. A replacement cluster for your 2007 van will need programing as its not plug & play for that year.
Graham Taylor
Postby austinthomas » Mon Feb 15, 2016 8:37 pm
Thanks Graham, I googled it , and there appears to be a few companies out there that provide a custom service, thanks for the link , much appreciated . :D
austinthomas
Postby Graham Taylor » Tue Feb 16, 2016 11:08 am
austinthomas wrote:Thanks Graham, I googled it , and there appears to be a few companies out there that provide a custom service, thanks for the link , much appreciated . :D
Plenty to choose from and handy if one near you as they may provide a while you wait service.
Graham Taylor
Postby austinthomas » Wed Feb 17, 2016 10:34 am
Hi Graham , I found a few on Google , the most efficient one seems to Lockwood Int @ 46.00 Pounds inc delivery , as opposed to 512.00 pounds for a new speedo clusster from Ford ! I phoned the IVA office here in South Wales and spoke to Inspector , he said to make sure to leave the perspex cover off for the inspection so he can adjust the dials if he needs to. So all in all it seems to be going in the right direction , again thanks for all your help on here guys , without it Im sure I would still be banging my head against a brick wall !
austinthomas
Postby Graham Taylor » Wed Feb 17, 2016 2:11 pm
austinthomas wrote:Hi Graham , I found a few on Google , the most efficient one seems to Lockwood Int @ 46.00 Pounds inc delivery , as opposed to 512.00 pounds for a new speedo clusster from Ford ! I phoned the IVA office here in South Wales and spoke to Inspector , he said to make sure to leave the perspex cover off for the inspection so he can adjust the dials if he needs to. So all in all it seems to be going in the right direction , again thanks for all your help on here guys , without it Im sure I would still be banging my head against a brick wall !
£46 inc del is really cheap well done. so lets hope that sorts your problem. BTW just be careful if you have to remove the needles as its easy to bugger them ;-)
BTW how desperate are you for the headlights?
Graham Taylor
Postby austinthomas » Thu Feb 18, 2016 1:14 am
I have the M.O.T on Wednesday, what I want to do is put it in for the M.O.T first just to make sure everything is fine before I order the parts and headlamps etc . They will do the MOT of the chasis number and put headlamp tape on the lights , then if its all alright I will order the parts and put in for the IVA .Do you know someone with headlights for sale ?
austinthomas
Postby Graham Taylor » Thu Feb 18, 2016 10:41 am
Yes me if I can get the replacements. I'm hoping I can get them this weekend or Wednesday at the latest. Old ones coming out will be genuine Ford as fitted at the factory from an 09 mk3 but all headlights are the same from 2002-2013.
Graham Taylor
Postby austinthomas » Thu Feb 18, 2016 1:42 pm
Yes Im intrested, can you let me know details etc.
Thanks Austin
austinthomas
Return to Connect Parts - For Sale & Wanted
