2008 Connect T230 for sale £500
Place all adverts relating to the Transit Connect in here!
Postby IanMcBride » Mon May 13, 2024 11:23 am
Pics (4).zip
For sale is my camper project Connect 230.
The rear has been fully insulated and carpeted. I've probably spent too much on this so far and now I've lost interest and don't want to spend any more on it. A roof vent has been fitted and a leisure battery was installed (This has been removed) the split charger is still there though.
After putting it in for an MOT, I got most of the work done (wheel bearings, new battery, brake cylinder, alternator, starter motor, patches on the sills) and the garage suspects that someone has tried to install an ST motor at some point. The fuse box had been messed with which led to a few electrical anomalies which will require investigation. The headlights don't work correctly is one mystery that needs fixed.
It's tidy enough inside with an ST steering wheel but the horn push is on the dash (?)
I want it off the drive. V5 in my name.
Aberdeen AB6
IanMcBride
Re: 2008 Connect T230 for sale £500
Postby TiviamTonal » Tue May 14, 2024 12:48 pm
Partially converted Connect 230 - Needs Work
Insulated & carpeted rear
Roof vent installed (Leisure battery removed)
Recent MOT work (wheel bearings, battery, brakes, etc.)
Electrical issues (fuse box, headlights)
Interior tidy, ST wheel, horn needs fixing
Needs TLC, motivated seller!
Aberdeen AB6, V5 present.
TiviamTonal
Postby IanMcBride » Mon May 20, 2024 2:13 pm
Sorry but what was the point of your post? Grammar check?
IanMcBride
Return to Connect Parts - For Sale & Wanted
