After 29 years of ownership I’m thinking about moving my Mk4 2.0 OHC SWB Transit on
The Engine was rebuilt 20,000 miles ago with little expense spared,Rebored, New Pistons and Rings, New Valves, New Oil pump, New Water pump, Kent Cam Shaft, new Borg and Beck clutch, New front wheel bearings, New front Discs, and it’s had some bodywork done. The cab interior is very good and clean and essentially it runs nice and has power steering.
It’s just had a new MOT, and new Varta battery. The underside is clean
That’s all the good stuff, the bad parts are that there were three advisory’s on the MOT.
Both front inner wings require replacing, and the windscreen has a crack at the top, I haven’t had that done due to the fact that the metal surround around the screen is rusted and requires fabrication of a new lip probably all the way round
And while the inner wings, surround repairs and screen replacement are all possible it needs a new owner who has the time and expertise to accomplish this work.
I have more photos but could upload them here,
PintoBill
Top
