Ford transit mk6 2.4TDCI 135bhp LWB HiTop
Sell all Transit Vans, Pickups, New and Old Here! [No Trade Ads]
Postby Colyer motorsport » Fri Sep 13, 2019 1:59 pm
2004 mk6 transit 2.4 tdci. Very clean van for 15 year old van 4 owners from new. just had new fly wheel and clutch and master cylinder less then 1000 miles ago.Just had new vac pump and full service. Just had 2 recon injectors fitted just need to get them program in and have 2 more to go with van. Van is fitted with tail lift all working with 2 remotes also fitted with fiamma wind out awning with 3 sides so turns in to tent. Van as had all rust work done had all new brake lines about year ago. 2x rev cameras with 7inch screen
I have loads of paper work to go with the van
2x sets of keys
Electric windows
Rear light bar on roof with 3 red led lights
5x amber leds fitted to front
2 x plugs fitted in rear with electric plug in on side of van
Does have 2400 watt inverter fitted with 2x leisure battery’s but I will be removing from van can be left in for the right deal.
VAN AS NOT BEEN USE AS A WORK VAN
The van as no MOT but only thing it will need is 2 tyres and only reason I have not done mot is just don’t have the time and not use van in last 2 months. due to the injectors need programming the van is hurting on tick over after about 5 minutes from start up but runs fine pulls very well in every gear starts up every time.
Van on 1730000 miles
I got this van about 7 months ago with the plans to turn it in to camper/race van for my son kart racing but due to things changing I no longer need a van this size only reason for sale.
New parts in last 6 months
New flywheel and clutch less 1000 miles ago
Master cylinder
New Vac pump
4x recon injectors only 2 fitted
New sump
New fuel rail pressure sensor
New IMV
New oil pressure sensor
Full service done 50 miles ago
£1600 I might be interested in swap for smaller van or car.
Colyer motorsport
Return to Transits For Sale
croncroncron
