by Blitzer » Fri Mar 05, 2021 2:51 pm
Ford Transit 1992 2.5 turbo diesel LWB twin wheel dropside truck with long all alloy body and working tail lift for spares or repair. From outside van looks presentable as in 2017 cab was overhauled with new arches and front wings and a full respray in white by the company who owned it who i work for but does reqiure a lot of welding to the underside of the cab including steps inner seals front crossmember some outriggers and suspension mounts. Inside the cab there is no carpet and it would benefit from a clean up, the drivers seat has been re upholstered due to the usaul wear, Engine runs ok and has had a mechanical fuel pump fitted instead of the original one with the wiring, new rad has been fitted and gearbox is also ok I bought it off the company in January when it failed its MOT but it is to much work for me to do so i want to move it on. Van is currently Sorn and located in Kent, the log book is in my name. A good project for someone or a good source of spares. Forgot to mention the van has only done approx 71,000 miles which i believe is genuine as it has been used mainly as a site vehicle on a large pharmaceutical site and i have worked with the section who use the van for the last 15 years and it was there before i was.
