by MinorMatt » Sat Mar 07, 2015 10:47 pm
Yes - its just put the gearbox, mount, crossmember, flywheel, clutch, clutch cable, pedal and propshaft in (with a flywheel)
You will also want the plastic bit that pop rivets to the floor round the gearstick.
It will have a permanent fault code logged (ECU light will be up for 5 secs when starting) but it won't affect it running
