I have a tatty but running 1972 (free tax) W115 mercedes 220 saloon, car runs fine other than a slight clonk from the front suspension somwhere, its very reliable, will start even after sitting for a fortnight in the winter weather, pretty much everything works except the window squirters and the hazard lights (switch is broken)
The car isnt MOT'd and the sills will definatly need doing (panels are available still) it looks fairly clean underneath although the lower rear quarters and the rear valance need replacing as well. Its fine to use everyday, i have done loads of miles in it since i bought it and it easily copes with modern traffic, brakes are top notch, its an auto with power steering and drives really easily and it will cruise at 70mph no bother. the body work isnt as bad as the patches of primer make it look by the way, its generally pretty solid, parts are easy to get, MB still keep most spares in stock (headlight lens £16.50 available next day delivery) and if your localish to me in essex theres a merc scrappy in billericay.
Its not worth a fortune so im not expecting a super van, I would ideally like to swop if for a van that runs and drives even if it needs work for the MOT, something old would be great, but anything considered even if its not (shudders) a Transit.
Ignore the cab sign, put it on for that "cuban" feel.
