Sbrem wrote:My mates have both a 52 plate and 54 plate transit vans,they are equipped with the durashift est automated transmission,the system provides push-button manual gear changing at the driver’s fingertips.
"Durashift EST is based on a conventional five-speed manual gearbox, but requires neither gear lever nor clutch pedal. Instead, the driver can change gear manually by operating ‘up’ and ‘down’ selector buttons on the steering wheel, or can simply put the vehicle into fully automatic mode. Additionally"
This durashift transmission is the one that i am after,surely there must be some ford transit tourneo's fitted with this transmission,I know they are going to be like hens teeth to find,
If any one could give me any pointers on maybe where is the best place to source these vehicles I would be most grateful
Tourneo`s are all front wheel drive,durashift is a RWD only gearbox/drivetrain.
You may find a normal spec. minibus (RWD) with durashift but i`ve never seen one,ask a dealer if they were ever available or an option.
Your mates vans are both RWD.
As said,true automatic not available in transit`s after smiley ones.
