Make:VW
Model:Golf
Colour:Red
Year:1999
Engine size:1.6 8v
Fuel type:petrol
Transmission:manual
Mileage:just turned 73k
MOT:Till july
Tax:Till july
Price:£1800
Description:
not much to add as the car is standard apart from gt tdi front seats and no rear window wiper i do have the motor just needs a wiper and arm and hey presto.
As far as paint work is concerned its ok it shines all the time but is slightly swirled, laquer is peeling off the passenger side wingmirror and a bit on the drivers side no bigger than 3mm square.
Timing belt was done at about 67k i have the recipt to prove this.Rear caliper was replaced lastyear as were rear disks and pads, fronts were done a month or 2 ago.
the bad points of this car is as follows and is reflected in the price,
There are now none see update down bottom
Pictures will follow
I am happy to answer any questions
PM's are what i want no silly offers or i just wont reply
forgot to add i have fixed the abs fault it was due to a split wire and also the battery light has been fixed that was a faulty relay for the light.
also cleaned out the throtle body and intake pipes and new MAF sensor fitted which cost the person who broke it £120+ with recipt to prove its a vw one.
that is all
