Mk5 TD Minibus breaking
Postby MinorMatt » Wed Oct 21, 2020 9:16 am
I have a W reg mk5 SWB, TD 12 Seater (no rear seats) minibus in at the moment for breaking...
It has ABS, Twin Airbags, Electric Windows, Electric Mirrors etc
Anybody need anything? I will only have it for a month or so before I will have removed anything I think is worth having and it becomes a metal cube!
Lucas Laser 2000 & IDS
95 N Hallmark (white)
96 P 150 TD 100PS LWB Hi-Top
96 P Autosleeper Duetto
2 x 2006 Mk7s
Re: Mk5 TD Minibus breaking
Postby 00353theking » Wed Oct 21, 2020 9:44 am
How much do you want for the electric windows inc door cards and wiring i want to fit them in my van
Sent from my SM-G965F using Tapatalk
00353theking
Postby MinorMatt » Wed Oct 21, 2020 10:03 am
Postage to AUS will be ridiculously expensive!! Do you have the high spec dash loom?
2 x 2006 Mk7s
Postby Motorhome perils!! » Wed Oct 21, 2020 7:15 pm
Hi, What engine is in it, does it run
and how much would you want for it?
Motorhome perils!!
Postby 00353theking » Wed Oct 21, 2020 7:32 pm
You could post them to portsmouth i can take them back with me next year, not sure about the dash loom , it has central locking could you tell by the vin number ?
If it dosent have that type of dash loom can it be fitted ?
00353theking
Postby MinorMatt » Thu Oct 22, 2020 9:30 am
Portsmouth isn't a problem - I could probably even drop bigger stuff off there in person.
Chances are you have the high spec loom. If you take the "speaker" cover off in the footwell - if there are 2 sockets there then you have the high spec loom.
If you pop the either of the 2 square blanks out of the dash (the group of 2) and there are red sockets behind - then you also have the high spec loom...
If you look in the engine bay, under the scuttle panel and there is a thick wire in each top corner with a single round connector (for the heated windscreen) then again you have the high spec loom
2 x 2006 Mk7s
Postby 00353theking » Thu Oct 22, 2020 9:43 am
MinorMatt wrote:Portsmouth isn't a problem - I could probably even drop bigger stuff off there in person.
Ok i will check ,
But if i dont have the high spec loom can it changed ,
Or could an auto electrician wire them up ?
Thanks Gerry
00353theking
Postby MinorMatt » Thu Oct 22, 2020 10:43 am
Motorhome perils!! wrote:Hi, What engine is in it, does it run
Its a 2.5TD - the bus was originally 85PS - but I am not sure yet whether its a turbo engine that's had a bosch pump fitted, or a non turbo that's had a turbo and all the bits fitted.
I *suspect* its the latter but im not sure.
£350. You can see it running and drive it (off road and without brakes!) if you want before it comes out.
2 x 2006 Mk7s
Postby Riggard » Sat Oct 24, 2020 8:35 pm
I'm looking for a few plastic parts for my mirrors. Numbers 10, 7 and 6 in this picture: https://ford.afora.ru/img/cgm/Z001313600.gif number 10 in the picture.
One of each should be enough, but if you have a few, that's even better.
Happen to have these and is it possible to ship to the netherlands? Should fit in an envelope I reckon.
Riggard
Postby MinorMatt » Mon Oct 26, 2020 9:49 am
Riggard wrote:I'm looking for a few plastic parts for my mirrors. Numbers 10, 7 and 6 in this picture: https://ford.afora.ru/img/cgm/Z001313600.gif number 10 in the picture.
Ahh the bits that always go missing...
I try to keep them for myself tbh, but I will see whats on it later
2 x 2006 Mk7s
