Masses of Mk3/4/5 parts - far too much to list
Re: Masses of Mk3/4/5 parts - far too much to list
Postby meerkatmag » Sun Apr 21, 2024 10:57 am
MinorMatt wrote:
meerkatmag wrote:Hi, Do you have a power steering pump bracket for mk3,4 or 5?
I think I have both parts of the bracket for mk4/5 (the one on the bottom nearside of the 2.5Di engine)
Sorry I already found one online, cheers for looking.
1988 transit MK3 2.5 tdi with intercooler
meerkatmag
Postby freyah » Wed May 01, 2024 8:52 am
Hello! Do you have a dual passenger / bench seat to suit a 1998? Mk 5 however I believe the mk 4 seats fit too.
Cheeres
freyah
Postby SarraSaffron » Tue May 07, 2024 11:42 am
Hi Matt - I'm after inner sill and boxes for a mk3 minibus if you have one? thank you
:D
SarraSaffron
Postby MinorMatt » Thu May 09, 2024 2:53 pm
freyah wrote:Hello! Do you have a dual passenger / bench seat to suit a 1998? Mk 5 however I believe the mk 4 seats fit too.
Cheeres
I don't anymore sorry
Postby MinorMatt » Thu May 09, 2024 2:54 pm
SarraSaffron wrote:Hi Matt - I'm after inner sill and boxes for a mk3 minibus if you have one? thank you
:D
Not quite sure which but you mean - the front steps?
Postby crazylegskev » Sat Jun 22, 2024 8:51 am
Hi, just had a cam belt snap. 2.5di. what are the likely outcomes and do you have the parts? Would it be easier and cheaper to replace the engine?
crazylegskev
Postby MinorMatt » Wed Jun 26, 2024 10:13 am
crazylegskev wrote:Hi, just had a cam belt snap. 2.5di. what are the likely outcomes and do you have the parts? Would it be easier and cheaper to replace the engine?
Take the rocker cover off and have a look
1 in 1 chance you will have pushrod damage
1 in 3 chance you will have rocker damage
1 in 10,000+ change you will have valve damage.
Basically all you need to do normally is remove the rocker assembly, and retime the engine.
Replace or straighten any push rods and replace/reinstall the rocker assembly
Set valve clearances and you are good to go.
I have used rocker assemblies and push rods :)
Postby petethetug » Mon Jul 29, 2024 10:45 pm
I need the following new parts for a Mk 4 transit A4LD box:
Vacuum Governor.
Vacuum modulator.
Vacuum Pump.
Thanks,
Pete the Tug.
petethetug
Postby MinorMatt » Wed Jul 31, 2024 10:19 am
petethetug wrote:I need the following new parts for a Mk 4 transit A4LD box:
Vacuum Governor.
Vacuum modulator.
Vacuum Pump.
Thanks,
Pete the Tug.
Sorry no Automatic bits
Postby Slow » Sun Mar 23, 2025 11:16 am
Hi mat
Do you have an air filter box for a 1992 turbo engine
Regards
Slow
Postby Chug » Sun Mar 23, 2025 11:29 pm
How about a camshaft for a turbo Matt?
Chug
Postby MinorMatt » Tue Mar 25, 2025 4:49 pm
Slow wrote:Hi mat
Regards
I've got mk5 bits but not mk4 - is this the one on top of the engine? I did see your post - why can't you keep your mk5 one?
Postby MinorMatt » Tue Mar 25, 2025 4:50 pm
Chug wrote:How about a camshaft for a turbo Matt?
Sorry but no
Postby Azbo » Thu Apr 24, 2025 6:19 pm
Hi Matt,
Before I send off my injection pump for a refurb (£540) would you have a Bosch pump for banana 2.5di ? My pump is
Bosch VE 0460 414145 686-2
Anything that will fit is ok.
I changed the engine few years back so don't know that the pump on it is the original, always worked for me though!
Azbo
Postby MinorMatt » Thu May 01, 2025 2:56 pm
Only ones that need refurb
