Masses of Mk3/4/5 parts - far too much to list
Re: Masses of Mk3/4/5 parts - far too much to list
Postby MinorMatt » Tue Nov 23, 2021 10:29 am
conrod wrote:do you have a good/new mounting plate for a steering box? Manual and PS box are the same, as you probably know!
I don't have a steering box mount sorry
Postby Chug » Tue Nov 23, 2021 11:17 am
Matt, have you got any brake and clutch pedal rubbers?
Chug
Postby MinorMatt » Tue Nov 23, 2021 11:58 am
I have new genuine clutch and brake pedal rubbers... but only the "square" type fitted up to 1997/8ish before the mk6 hexagonal type were introduced
Postby Chug » Wed Nov 24, 2021 9:57 pm
yeah they're oblong ish, not the later hex like mk 6 ones, my mate reckons he's got some and will get them on sat but I'm not holding my breath, so just in case, how much for a couple please Matt?
Chug
Postby crystalvoyager » Thu Nov 25, 2021 12:35 pm
Hello, do you have any front hub nits for the mk5 particularly left hand threads. Thanks
crystalvoyager
Postby MinorMatt » Sun Nov 28, 2021 6:02 pm
I do somewhere...
I definately have a hub assy on the shelf I could nick a nut from if required (but only 1 side..) which side do you need?
Postby MinorMatt » Sun Nov 28, 2021 6:07 pm
crystalvoyager wrote:Hello, do you have any front hub nits for the mk5 particularly left hand threads. Thanks
I have just checked with my suppliers - and I can get both sides :)
Postby Chug » Tue Nov 30, 2021 6:27 pm
Bump.....How much for a coouple of pedal rubbers then Matt?
Chug
Postby MinorMatt » Tue Nov 30, 2021 7:59 pm
Sorry Chug, I didn't see your reply :oops:
£20 posted for a pair
Postby dochie » Tue Nov 30, 2021 10:38 pm
Here is one that will test you.
Do you have a heated seat switch.
It is a rectangular switch fitted to the side of the plastic moulding at the base of the seat on my Mk 4 motorhome.
Have tried looking at Ford cars from this era but cant find anything.
Dochie
dochie
Postby MinorMatt » Sat Dec 04, 2021 11:25 am
I don't have a mk4 one... I've got a mk5 one (somewhere!!!) but thats not the same. I will have a look and see what I can find
Postby MinorMatt » Sat Dec 04, 2021 11:29 am
Am I right in thinking that this is the one you need?
Postby MinorMatt » Sat Dec 04, 2021 11:31 am
Or is it more like this?
Postby dochie » Sun Dec 05, 2021 12:45 am
Thanks Matt will check in the morning and let you know
Dochie
dochie
Postby dochie » Sun Dec 05, 2021 8:23 pm
Hi Matt
Its the one in the first picture that I need.
You must have a huge and varied amount of stock so thanks for raking that out for me.
If you let me know how to pay you I will have the switch.
Dochie
dochie
