Masses of Mk3/4/5 parts - far too much to list
Re: Masses of Mk3/4/5 parts - far too much to list
Postby Chug » Mon Dec 06, 2021 10:37 pm
Thanks Matt, but eventually my mate turned up with some used pedal rubbers, but still much better than mine, especially the clutch one which was through to the metal, so I'm sorted now. I felt bad though as I had been moaning how he hadn't got back to me, but his missus wasn't well :oops:
Chug
Postby pete_the_4x4 » Sat Dec 11, 2021 9:50 am
Hi still after mk5 panels what have you got ?
if you think my van is dirty you should see my pants
pete_the_4x4
Postby MinorMatt » Sat Dec 11, 2021 10:46 pm
Bonnets
Doors
Wings
Arches
Bumpers
Side Loaders
Front crossmembers
rear crossmembers
allsorts really
Postby Manchestermatt1986 » Tue Dec 14, 2021 12:01 am
I'm after a mk4/mk5 passenger twin seat. A foldable would be preferred
Manchestermatt1986
Postby MinorMatt » Tue Dec 14, 2021 9:49 am
I've got one out of a late mk5 - so unfortunately its not the lift up type. Thats the only one I have in stock atm
Postby Manchestermatt1986 » Tue Dec 14, 2021 10:53 pm
MinorMatt wrote:I've got one out of a late mk5 - so unfortunately its not the lift up type. Thats the only one I have in stock atm
So this will go into my ford herald squire. Its built on a mk5 chassis I believe. Its a 2000 reg but I'm pretty sure it's mk5.
Do you have a pic?
How would we go about postage/delivery. I'm up in Manchester?
Manchestermatt1986
Postby MinorMatt » Tue Dec 14, 2021 11:12 pm
There arn't really many ways to post a seat I'm afraid! It would have to be collection only...
Postby Chris21r » Wed Dec 15, 2021 9:21 am
Dropped you a mail Matt.
Chris21r
Postby Eagle.nl » Sun Jan 09, 2022 5:25 pm
MinorMatt wrote:Guys I still have a huge amount of stuff for mk3/4/5 vans
New old stock, used, genuine and pattern - if you need anything give me a should and I will see if I can help!
Hi, I am looking for grille brackets, Ford smiley '97, both sides and a bumper bracket, left side one.
I am from the Netherlands, do you send overseas as well?
Harm
Verstuurd vanaf mijn SM-A705FN met Tapatalk
Eagle.nl
Postby Eagle.nl » Sun Jan 09, 2022 8:38 pm
excuse me for not doing it right, its my first time.
Hereby picture of what I mean by the bracket of the grille
Harm
Eagle.nl
Postby Mcgeordie » Sat Jan 15, 2022 4:53 pm
Hi, not sure if you can help but I'm looking for the power steering pipes from the rack for a 1999 mk5 transit "smiley". There are 4 pipes that come from the rack, 2x are threaded screw and 2x are push in with a holding plate. I am looking for the 2x push in with the holding plate, 1 goes from the rack to the cooler and the other from the rack to the pump, or if it is easier a full set. I know its a long shot but I thought I would ask.
Mcgeordie
Postby MinorMatt » Mon Jan 17, 2022 9:46 am
Harm
I've missed this, I have some new grille brackets - do you need the one pictured, or the one for the other side?
Postby MinorMatt » Mon Jan 17, 2022 9:47 am
Mcgeordie wrote:Hi, not sure if you can help but I'm looking for the power steering pipes from the rack for a 1999 mk5 transit "smiley". There are 4 pipes that come from the rack, 2x are threaded screw and 2x are push in with a holding plate. I am looking for the 2x push in with the holding plate, 1 goes from the rack to the cooler and the other from the rack to the pump, or if it is easier a full set. I know its a long shot but I thought I would ask.
Sorry, I haven't got any PAS pipes :(
Postby Eagle.nl » Mon Jan 17, 2022 4:55 pm
Hi thanks for your response.
Both sides would serve me best
Eagle.nl
Postby MinorMatt » Tue Jan 18, 2022 10:06 am
I will check whats in the box of supports
Users browsing this forum: Wes81
