Various Mk3, Mk4 & mk5 parts
Re: Various Mk3, Mk4 & mk5 parts
Postby Ian1 » Thu Sep 02, 2010 1:17 pm
Hi,
I'm after the rail that fits on the bottom of the front windows and the small nylon block that slides along inside. Mine has rusted and worn so can't open the window. I think driver and passenger windows are the same.
Cheers,
Ian
"It's more fun to drive a slow car fast than it is to drive a fast car slow." - Caroll Shelby
Ian1
Postby Nomolos » Thu Sep 02, 2010 5:22 pm
Hello there, i am looking for a rear 3 leaf, leaf spring for a Mk3 Transit SWB on a 99 plate, any idea how much with postige to CF33 Bridgend?
Best Regards
Andrew
Nomolos
Postby trippydog » Thu Sep 02, 2010 6:07 pm
Andrew - sorry can't help you on that mate.
Ian - pretty sure I don't have those bits but will have a good look for you tomo.
Former Van: '93 190 TD LWB High Top... Ex Police Riot Camper. Sad to see her go.
Check out our site, Go On Go Out if you are looking for live music in Portsmouth.
trippydog
Postby transit dave » Fri Nov 05, 2010 10:22 pm
Have you got a cup holder and an aerial for a semi high roof just the mast???
Thanks Dave 07807 979 973
Wtd - dished wheel cap for 6 stud wheel
transit dave
Postby trippydog » Sat Nov 06, 2010 12:15 am
transit dave wrote:Have you got a cup holder and an aerial for a semi high roof just the mast???
No I don't, sorry.
trippydog
Postby County4x4 » Sun Nov 07, 2010 12:18 pm
Hey Si,
What have you got in the way of Front Door Locks/Catches for my Mk3 doors? i don't need the barrels just the mech as all the placky insulation has gone to the dogs and only work with a continuous supply of WD . . . . . :( :shock: :oops:
Do you know how late a model lock will still fit in a mk3? Or am i stuck with originals . . . . .? :? :?
Thanx,
Andi
County4x4
Postby MinorMatt » Sun Nov 07, 2010 7:03 pm
i dont suppose you have a water pump pulley for a 2.5 di spare?
Postby madbri » Sun Nov 07, 2010 7:53 pm
MinorMatt wrote:i dont suppose you have a water pump pulley for a 2.5 di spare?
mat ive got 1 if all else false :wink:
madbri
Postby MinorMatt » Mon Nov 08, 2010 12:45 am
Scrub that - its the oil pump pulley and a set of push rods I need :?
Postby trippydog » Mon Nov 08, 2010 12:35 pm
MinorMatt wrote:Scrub that - its the oil pump pulley and a set of push rods I need :?
Got a set of push rods and some pulleys - not sure which ones though. Hopefully should be able to find out later today.
Andi - I have some mk3 barrels but I think the only front door mechanisms I have are mk4, not sure if they'd fit. If you are local you are welcome to come over and have a look.
Cheers.
trippydog
Postby County4x4 » Tue Nov 09, 2010 9:35 am
Thanx Si,
i'm not exactly local(Brighton) but i sometimes pass that way, so, i'll let you know if i am in the area. Are the mechs still attached to the doors? Meanwhile i'll post a Q for the knowledgeable bods in the tech threads to see what fits.
Andi
County4x4
Postby trippydog » Tue Nov 09, 2010 12:38 pm
County4x4 wrote:Thanx Si,
Andi
Ok, no problem. They aren't attached to the doors.
trippydog
Postby MinorMatt » Tue Nov 09, 2010 7:11 pm
Whereas I am only a few miles away and I go to Haywards Heath every weekend - i could get them there if it helps
Postby new2transit » Thu Nov 18, 2010 12:13 am
Hi,
Bit late to this posting but would you happen to have a MK5 steering wheel in decent condition? Also after the instrument panel (and all clocks) for 2000 MK5 smiley?
Cheers
new2transit
Postby trippydog » Thu Nov 18, 2010 12:25 am
new2transit wrote:Hi,
Cheers
Hi mate.
I've got a steering wheel but think it's from a mk4... not sure if it changed on a mk5. Definitely have some mk5 clocks (without rev counters), might have the surrounding plastics but don't have any full dash's left.
Will have a look for you tomorrow and let you know.
Cheers.
trippydog
